So, I’ve had to get involved in other non-web endeavors for quite a while (still doing them), but now have to get back into web design.
I have not upgraded to v6 yet, and am working on the latest version before that. Is there a huge learning curve to get started in v6? For now, I will be starting sites fresh, not updating older ones.
And. can someone point me to info regarding having the two version running on the same machine simultaneously?
I have another question, which I will resrve for another post!
The only thing you can’t do is open a file in 6, edit it in some way, save it, and then re-open it in 5.x. But when you open your 5.x file for the first time in 6, Freeway will make a backup before it lets you edit. You always have a way back.
No - you can treat 6 like your previous version, if you want to.
However there is more in 6 that makes the inline and responsive methods easier - but if you weren’t doing that before 6 makes it easier to learn.
