[Pro] Thumblie picture caption question
Silly question but I can’t find where to add picture captions to each image in Exhibeo, using the Thumblie template.
I’d also require the image caption to appear below each thumbnail.
Thanks :slight_smile:
http://www.in-volve.co.uk/test/News/news1.html
Exhibeo mailing list
Hi Neil,
Open up the Thumbnail view (Command-1) and double click the image you want to add the title or description to.
Hope this helps,
Hi Joe,
Many thanks for the swift reply - I didn’t even know that options screen existed!
What I really need though (and what the client has requested) is that the caption also appears under the initial thumbnail, but I can’t see a setting for that?
Many thanks.
It’s not currently possible to do that in the Thumblie theme – I’ll log a suggestion.
Have a look at Bloxx, or the thumbnail gallery in the Showcase application that comes with Freeway.
Thanks for the swift reply Joe.
Unfortunately its a responsive layout so its a challenge using showcase, but Bloxx will be ok until its added to Thumblie.
Many thanks :slight_smile:
