Hi - does anyone know of a ticker tape effect by a javascript so i can have 1,2,3 messages scrolling? Just my own suff no need to pull info from anywhere else. Just a simple ticker effect with more than one message and links if poss?
I found a couple but didn’t work one was in French so had to guess a fair bit
J
You mean other than FW’s own Ticker Tape
yes - I think that would work but it has a box around it? can this be removed?
Oh and would like to add links if poss
I forgot about this one http://www.deltadesign.co/newsticker.html
This is a Walter special that I had tucked away for a rainy day. Would it do the job?
Ignore the File Download - that is for the text resizer not the ticker which uses script/protaculous.
great would be perfect!
Revisit the example page to download the file. http://www.deltadesign.co/newsticker.html
And this is the thread it came from http://freewaytalk.net/thread/view/74098#m_74191
great thank you have downloaded.
Will take a look at the thread now.
