http://justineasthall.com/ticker.html
Is there a way to remove the box surround the text? I think I once saw a simple way of doing this Action in pure HTML?
Thanks!
waltd
(Walter Davis)
February 14, 2012, 4:07pm
2
The box on your example page has the classname ‘tickeritem3’, so you could remove the border by adding this style to your page:
.tickeritem3 {
border: none;
font: 24px/24px normal Helvetica, sans-serif;
color: #999;
padding: 0;
margin: 0;
Thanks!
Just tried adding after /Head - but not working? Do I need to add where?
waltd
(Walter Davis)
February 14, 2012, 4:34pm
4
Did you wrap it in tags?
No I literary just added that code inside the header - should I?
Oh and just to clarify - I mean no background also so its just text nothing else
I did just wrapped that code with the tags still no joy?
waltd
(Walter Davis)
February 14, 2012, 5:06pm
7
When you copied from Freewaytalk, you got “curly quotes” instead of “typewriter quotes” for the type=“css”. That’s what’s making your CSS fail. Try typing the code directly, or copy and paste this:
<style type="text/css">
.tickeritem3 {
border: none;
color: #999;
padding: 0;
margin: 0;
</style>
See if that helps. Also, I notice I wrote type=“css” and it should be type=“text/css”, so that certainly is contributing to the problem.
Great! that works - do I just add
background: transparent
? or soemthing like that?
Ahh no go again - you can’t change the width! and it can’t be ‘inline’ and it will end half way through the text if its too long -
Anyway thanks for you help - I found that the HTML marquee worked so I tried that, it was really good except in IE 8 where it disappeared!
Back to a list
waltd
(Walter Davis)
February 14, 2012, 6:12pm
10
Sure you can, just add width: 100% or some other valid value.
Back to a list
Thanks - but trying the Maquee again - I can add links here - but it works fine on webkits but vanishes in IE??
bottom left column
its only a really basic bit on HTML right??
Its just a markup item then in that surrounding quote2div - not inline… if I put the HTML item inline then it disappears from all browsers if its absolute then it disappears from IE only…
This is driving me nuts? It should be working fine in IE!? Gonna start another entry for this see if anyone can figure this out - thanks again
J
