Anyone know a good place to get some tillable background textures? I’m primarily looking for paper and blueprint type backgrounds.
Thanks!
Thanks!
Google is your friend.
Yes, but Google finds a lot of crap too. ![]()
It does when there is so much out there - but c**p to you is Manna to someone else.
I am afraid that this sort of quest is pure legwork.
Darn. I was hoping to avoid work.
While we’re on the subject, I’m assuming that a tiled background, say something like 300 x 300 pixels, is going to be smaller and more efficient than say a single 960 x 1000 pixel image.
Is my assumption correct? If not I probably should be looking for larger single images.
Depends on the individual images/compression/resolution/file format etc.
A smaller image at the same compression/resolution/file type will be more efficient than a larger one.
Absolutely. But you might find something here http://www.cgtextures.com/
Richard
http://subtlepatterns.com/ is a possible source.
Thanks guys.
