Can anyone help with step by step instruction on installing The Tiny Browser plugin? I want to use it to enable my client to upload audio files. The instructions that were provided we poor at best and I am a novice at some of this stuff. I know know how to upload the folder of file to the server but I’m lost as to what to do next.
Here is the instructions. The challenge for me is steps 2&3
The standard TinyBrowser installation, this integrates TinyBrowser as a custom
file browseer with TinyMCE.
Copy the tinybrowser folder and contents to your TinyMCE plugins directory.
Place the following javascript link after the link to TinyMCE (tiny_mce.js):
NOTE: The above link assumes TinyMCE is installed in your website root
directory, you will need to amend the link to your specific setup! -
Add this line to your TinyMCE init:
file_browser_callback : “tinyBrowser”
Edit the TinyBrowser configuration file (config_tinybrowser.php). The most
important settings are the file paths (these will be automatically created on
your server by TinyBrowser if they do not exist) and also the security
settings - if $_SESSION[‘tinybrowser’][‘sessioncheck’] is not configured you will only be
able to browse files.NOTE: If your server is Unix-based. you may wish to modify the
$_SESSION[‘tinybrowser’][‘unixpermissions’] config value, which decides permissions. -
All done! Now you will see a browse button in the TinyMCE dialog windows for
plugins like image, media and link - just click this button and TinyBrowser will appear.
