Advise required on how to speed up the loading of the following site.
The images are PNGs and are 500-600Kb apiece, which is way over the top for the web. Make them JPGs instead, and you’ll reduce the size by anything up to a factor of ten with no loss of quality. There’s no reason for them to be PNGs that I can see?
Big images always means bigger files. As part of the design process think about how to reduce the image sizes (physical image area) you use then play around with files types and settings. Google does reward a slim site in the search engines albeit slightly.
On 21 Jul 2011, at 21:57, “Mike Thornley” email@hidden wrote:
Hi
I’ve down saved the images, are they still to big, need to keep a nice quality.
You can reduce these images loads more and still retain good quality.
I think I mentioned the size of your bg image to you in a previous thread and the same principle applies to your slideshow images.
And Paul’s suggestion to use jpegs will help drastically!
Your overall page size is nearly 8Mb - that is huge.
I should also mention that you should give your pictures proper names - at the moment dsc0006.png is meaningless as FW converts your file names into the Alt text which should be a description of the image to help you gain SEO brownie points.
If you dont want to change the file names then at least add in the Alt text yourself.
Hi Mike,
You are getting there. Download ImageOptim (http://imageoptim.pornel.net/) and run your jpegs through the software. I managed to compress one of your 400K images down to just 150K.
Also if you open your images in Preview and do a Save As (this would give you the chance to change the file names (eg man_fishing_from_bank.jpg)
If you then look in the bottom of the window you will see the File Type selector, the Quality slider and the finished file size.
Adjusting the Quality slider will affect the file size. And as Tim suggests you can get down to 130-150K without much problem - more if you dont mind a compromise on quality.
Try a few and view in your browser to check the quality.
Re: Tim. I just used imageoptim which is a great prog and it shaved off 100% off my png files. I got it to replace the files in the Media folder without doing a backup (though I kept originals on external drive for safety)
Sadly Freeway did not recognise the amended png Media images when I tried to publish and put my FWsite in a browser. I had to go to resources and sort it out there …
I meant shaved off 10% off my png files … but by amending them it meant anything in my archives rejected the files so if I looked up an archived folder version of my site it had issues
