Hi Heather,
If the images are in the same relative location that they were previously, Freeway will find them automatically.
If not, then I think the best thing would be to create a Media folder next to your document and put your images in that folder. Then, within Freeway, you would choose Edit Resources from the Edit menu and look for images that are marked as missing. Select a missing image and click on Edit, then click on Locate in the Edit Graphic dialog. If you locate the image, Freeway will automatically try to locate other images that were previously in the same folder as the image that you’re currently locating.
Jeremy
