when I add the effects to the image on the left, seems ok only I would like the black to scroll up from the bottom of the image not from the centre down?
Also when I add opacity to the black html scrolling bar (see right) it breaks?
The Action just uses some default options available in the JavaScript library it uses. I will log a feature request for adding extra transitions to it.
On 20 Aug 2010, at 12:27, Mr worm wrote:
Hi Justin,
I was also trying to get this ‘scroll up from the bottom’ effect on my site a few weeks back, but never succeeded!
I would have thought it would have been an obvious default within the Transition FX action?
