Thanks for your reply. The settings that you sent more or less matched what Joe sent me back in June 2009 and since then I have had no problems.
I entered the settings that I have used before and I entered the setting that you sent down but still it does not work - the other 3 sites I’ve used this on all work - with either of them.
These are the setting I have used.
For on trigger: On Trigger - ticked; Effect - Slide Down; Toggle - ticked; Duration - 0.5; Delay - 0; Item - iten1A; Initially Hidden - ticked; Trigger On - Click
Tried it with :Effect - Slide Up - but that didn’t work either.
As I said my other 3 sites that I have done the same page for all work with the settings as above.
I’ve got a doctors appointment 12:50, so when I get back from that I’ll do a test page and see how that works and let you know.
Back on the case now. Thanks for the offer but i have done a test page and it worked, so it must be something I did on the site page, I’ll see what it is first and let you know.
