Hi -
I just added some text edits to a Freeway site I did a few months ago, now when I go to publish I get a Javascript error on the Transition FX?
See the error here
http://easthalldesign.com/help.html
See the website here - in some places it works?
working here
http://www.eb5regional.com/
Not working here
http://www.eb5regional.com/espanol/espanol.html
I removed all of the effects and reapplied to no avail.
Very frustrating as I thought I was only adding a bit of text now I’ve spent hours on it!
Any help would be GREAT!
Jus
Tychain1
(Tychain)
June 22, 2011, 3:41pm
#2
Try edit / actions and scroll down to the offending action and chose clear java error (or something like that)
This is from memory because I dont have any errors right now but this helped me on occasion.
Thanks will do - I have Softpress looking at this now -
Paul4
(Paul)
June 22, 2011, 10:25pm
#4
One thing to check - go to Edit>Actions and see if the Transition FX Action is listed as being embedded in the document. If it is, then switch it off and look for the Action that’s contained within the application and switch that version on.
