When the page loads, you get everything showing, then everything that should be hidden at ‘on load’ slides up. On other sites and also the ‘Freeway’ site when they used the action this did not happen.
Joe wrote that “In this example I want the content items to slide up when the page loads so it becomes obvious that there is actually some content there.” but what I need to know is how to do it with out the content items sliding up when the page loads.
Cheers for sending the settings, it’s made it easier to see what the
problem is.
If you don’t want anything to happen on page load then uncheck the
Page Load option. The settings from the On Trigger Section (i.e.
Initially Hidden) will be used, so it will toggle between sliding up
and down.
HTH,
On 22 Jun 2009, at 16:46, Gray Owl wrote:
On 22 Jun 2009, 10:48 am, Joe Billings wrote:
To do that you need to set the items to be initially hidden.
I hope this helps.
I have tried that Joe but it still slides up on Page Load. These are
my settings:
problem is.
and down.
HTH,
Thanks for that Joe, it now works how I wanted it to.
