Currently I’m using the TransitionFX action to get the map to show, This works fine, but if the user opens more than one map the previous one does not ‘close’ back up. The only way to get it to close is if the user clicks the ‘show map’ button again. Not a huge issue but the page ends up looking messy (and too long) if there are too many left open.
Could I use the ScriptyAccordion action to achieve the ‘automatic closing’ when a user clicks on a new map? Would this be a better solution? Can the ScriptyAccordion action be used on a mix tables and Google maps like i’ve done here? I’ve had a quick go with the action but struggling to find a tutorial or set of instructions for it.
Apologies, I’m working my way through it trying to sort it out and having issues with uploads at the moment.
I thought I’d finally sorted it - I used the mootools suite accordion actions and got exactly what I needed working perfectly - mainly the ‘groups’ feature of the accordion action which allows certain items to close when others are clicked on. All worked fine until I put my CSS menu back on and it dies, I get a 'Prototype and / or Scriptaculous libraries detected. I’d heard of clashes with the carousel action, but not with the CSS menu action.
