I’m sure this is covered here somewhere but just wondering how you customize the transitions in Showcase Gallery action?
I’m stuck with a white flash effect and would like a dissolve.
Is this achievable?
I’d also like to know if this is possible?
Joe2
(Joe)
March 4, 2011, 3:56pm
3
Hi guys,
There’s currently no way to have different transitions.
What a shame, so close yet so far.
Many thanks Joe.
carla
March 5, 2011, 10:38pm
5
Ah yes I would like the same thing. I love the show case action in almost every way but the transition is clumsy… No solution? anyone??
Thx
Another feature request for showcase would be for it to recognize the CSS3 formatting of objects beneath it.
I put a simple showcase slideshow over a couple of html items I had put gradient fills into and every time the slide changed it would remove the gradients from those items during the transition. Only to reappear once the image finishing drawing on the page.
