When I place this in DreamWeaver CS3 or CS4 and go through the instructions it works like a charm.
When I place the same graphic in Freeway it isn’t transparent. I tried to use the the Flash Extras action and select no color but that didn’t work. I tried to right click on the Flash document in Freeway and select Extended and enter the code: wmode=“transparent” in the Embed choice but that just made the Flash file disappear completely. Anyone know how to make it work?
Could you post a link to your broken page? That will be instructive.
Be sure when you use the extended dialog that you enter just wmode in
the Name field, and transparent (no quotes, no equals sign in either
one) in the Value field.
On Apr 27, 2009, at 7:46 PM, Alex Retivov wrote:
Does anyone know how have an imported flash document have a
transparent background in Freeway? I prepped the Flash file
according to Adobe’s site:
Thanks Walter! That worked. I didn’t realize that the name was part of the equation. Once I entered wmode in the name field and transparent in the value field, everything works properly. I don’t have this online yet but will post a link once it is.
