Slideshow set up, I followed a tutorial that Dan Jasker had kindly posted on his blog, and went back to scour the video again to make sure everything was done right. Slideshow fades to other images, yet other images that have a smaller height show other images behind them. Also they cut off the images that are wider on the right side. Is there a way to fix this, or do all images need to be the exact same dimension. Page is currently uploaded to http://www.elsamarley.com
Thanks!
Try making all of the image boxes the same size, and give the boxes a
background color to match your page background. Then if you import
your photos and scale them to fit inside the box, there won’t be any
transparency around the short sides to show what’s beneath them.
