[Pro] Trouble with nav menu rules
I can’t seem to get my nav bar to do what I’m telling it. I’m saying white type, no underline, green when hover, green when active etc. Then I might get blue type that IS underlined and no hover or anything!
I found an idea to use a new action in Freeway, but when I go to my actions list, I don’t find an action called 'CSS Menus Action in the list!
Ideas? Help?
The action is item dependent so you need to select an HTML item that contains a list. Item>Actions>CSS Menus (at the very top)
You create a list by having your menu items (names) separated by a return then select them all and in the Text inspector go right down to the bottom to click on the disclosure triangle next to ‘List’ and apply an indent.
You will then have access to the CSS Menu Action interface.
Hi David,
I’m sure what you say is somehow correct. But I have tried 3 times now to implement it and it doesn’t work for me. Do you use Skype? If so, maybe a quick talk would help.
I’m allanrockart on Skype.
Visit this link http://www.deltadesign.co/menu_stuff/softpress.html and download the example file
See if it works for you.
