Is there a way of removing the rounded corners on the Twitter Widget within the HTML markup box?
Gavin
Gavin
How are you adding this to your FW page? Using an action?
I ask because you mention a ‘markup’ box.
If you are using an action this creates an iframe on your page and the look of its content is governed by the source - ie Twitter.
Not easy to change the content. There may be some JS methods.
Any particular reason you don’t want your Twitter widget to look the same as everyone else’s?
You can link to your own graphic for certain things. What exactly are you trying to do - and can we see your example?
Thanks, Dave. I added it via a HTML Markup box - didn’t realise there was an action for it too. I’m sure, either way, the look is governed by Twitter, but I thought that the appearance could be tweaked, possibly only via CSS. Just wanted to double-check, since this site contains several boxes, but the Twitter feed is the only one with rounded corners - just jars a little, although with a square white background is liveable! Will have to reupload it and post a link.
Once you have done that we can see if it can be tweaked via CSS alone.
