I’m trying to set up redirect pages for iPhone. I have redirected my home page and have set the inspector page alignment to but it shows up on my safari iPhone browser aligned to the left. Any ideas?
My second question is: does this redirect work on other phones or just the iPhone? If not, is there a way to create a redirect for other phones as well?
Thanks, David
http://phelpssculpture.com/index.html
Can I suggest that you use one of the iPhone templates for this page - which are incidentally 320px wide and have no alignment set.
Also I would put some sort of header at the top of your page so that your visitor knows what site they are visiting.
carla
February 18, 2013, 5:30pm
3
Hi David
how can I find a template for iphone. I am going to try this for a site. would it be within the same website?
I have never done this before, but can figure it out once I know the first step
thx
The iPhone templates should be installed with your version of FW Pro - certainly in pre 6 versions.
Templates can be moved between versions.
carla
February 18, 2013, 7:38pm
5
thx David
I looked in template area but could not find
do I have to make a new site for this or can I make a iphone template page for iphone within existing site
In your Library>Application Support>Freeway Pro (5 or whatever) there is a Templates Folder.
You can copy Templates between different versions by putting them in the Templates folder.
I have sent you some.
You can create a new FW doc using an iPhone Template and then copy the Master from that FW doc into the Master section of your existing FW doc.
Hope that doesn’t confuse.
carla
February 18, 2013, 8:29pm
8
thx Dave
