This page has thumbnails across the bottom. Each thumbnail has two rollovers attached (using Rollover60). Mouseover a thumbnail displays a full window photo with text. (This covers the thumbnails, but invisible links on top continue to work.) So far so good. Now I want to click the thumbnail to make the text disappear. It does … but then won’t reappear again. I thought using the rollover ‘Restore’ command would solve this, but I seem to have introduced a complication!
PPS I can use the ‘Toggle’ option for the text rollover. This will restore each text, but requires another click to achieve it. I think most people would just move the mouse away from the thumbnail and expect things to work as from the beginning … Paul
David, the layout has evolved as I have produced websites on cathedrals. I started with exposed thumbnails, but wanted the large photos as big as possible. Then I went to full sized photos with no thumbnails, but simple arrow navigation. Since then I have realized that thumbnails give quicker and easier navigation. So the present format combines large photos and quick navigation!
Paul
On an individual basis you would use Toggle on the Caption to get this but it gets complicated when there is more than one Image/Caption as it will toggle when another event is triggered on another thumb.
And what is worse is that on iOS with no mouseover event it gets even more complicated
