[Pro] Unable to Publish Site
I suddenly am unable to publish my site. It no longer goes to my upload credentials, it is going to a folder search. Any thoughts on how I can get back to my site login info? Appreciate the help. Thanks
Have you chosen “File Copy” instead of “FTP” or “FTPS” in the popup at the top of the Upload dialog?
Jeremy
There is no popup anymore… it just disappeared… If I select to upload it goes directly to a folder to save it. I have uninstalled and reinstalled and the same thing happens. The correct site information is in the document setup as well. Any other thoughts?
I think that what you are seeing may be a dialog that is asking you to choose a Site folder. Freeway needs to publish to a Site folder before it can upload the site.
Jeremy
Jeremy thank you!!! That solved the issue. I am not sure why it had not done that in the past… but that was the issue…. Appreciate the help…
Jeremy
