Hi the underline on the linkes on my site wont turn off and i dont want the link to be underlined. How do i stop it?
Can we have a link to your page online somewhere.
Did you use the FW interface to add Link styling in the inspector or is it the default behaviour?
In Pro you can set the styles of your Links in several ways.
With the HTML item that contains your links selected look in the Inspector.
Down near the bottom is the Links section - may have to click the disclosure triangle to reveal its contents.
In there you can set colours and whether not they should be underlined. Just be careful as it is not easy to see what state the underline U is showing. 1 click is off but there are several options and you are best to watch your link on the page to see which one you have chosen.
You can also set Links on a page wide basis by doing the same thing with nothing on the page selected but the first method will win out over the page setting.
Hi thanks, it was set in the style and I have done it now.
Thanks for you help ![]()
