Hello there,
has anybody an idea to realize this (http://pax-immobilien.com/referenzen/) slider in freeeway?
Thanks for request.
Hello there,
Thanks for request.
Not precisely, but I did have an example up once where I used Carousel in two different-axis containers side-by-side. I’ll have a look to see if I can find it. It was oddly mesmerizing to watch. What you could create with Carousel would be a vertical effect with the list of residences on auto-scroll and the matching photos set to horizontal (the default). Because they would start at the same time, they would navigate in unison. They could be linked by placing a Carousel Tab or Carousel Text Tab in each of the vertical listings, set to link to the corresponding photo in the horizontal carousel. This should stop both at the same time, although I’m not sure if the vertical list would continue to run. What you definitely would not get in this case would be the very cool 4-at-a-time view in the text listing.
To answer your exact question, this effect is being done with MooTools, using an add-on script called lofslidernews according to the source. You can use MooTools in Freeway, but you have to swear off any other use of the core Prototype-based effects when you do. Weaver’s MooTools Actions are available at the Forge, and you should have a look there to see if there’s anything to help you if you want to go down that path.
On Jun 20, 2012, at 9:09 AM, H.Banken wrote:
Hello there,
Thanks for request.
Hi,
Give this a try… Carousel in Freeway
Neil.
Hi Walter, hi Neil,
thanks for your response.
I did it with the Carousel Action. Look here: websico.de is available for purchase - Sedo.com.
I would prefer the Carousel-Tab-Button Action, but it didn’t work for me.
It’s not exactly what i would reach, but it’s ok. My problem is solved.
Hi Walter, hi Neil,
I did it in Carousel. Have a look: websico.de is available for purchase - Sedo.com
