The easiForm action (v1.49) has been updated to be friendly to the PHP changes as of PHP 5.3 , this version as the previous version of the action is Freeway 6 Pro friendly and can be used with Freeway Pro versions from 4 and above. The action can be downloaded from Actionsforge: http://actionsforge.com/actions/view/55-php-easiform or from the http://easibase.com/ web site.
This v1.49 action update is a bit overdue due to a shortage of my time for making the changes needed to the easiForm script and encryption process, this update now brings the easiForm script up to v1.87.
Many servers are now using or starting to use PHP 5.3 so this update will prevent the need for using the PHP error_reporting action to suppress any deprecated warnings, if you where using the PHP error_reporting action to suppress these warnings I suggest when you update the PHP easiForm action you now either remove the PHP error_reporting action or deactivate it unless you are using it for other reasons.
