Hi there,
I am wanted to install the new FW Pro 6 update on my new Mac book pro Mavericks), downloaded Softpress all correct, opened Freeway but there is still 5.5 opening…
Do I have to reinstall everything for successful updating?
…can somebody help?
Jan Kobrzinowski
Means: Freeway 6 is launching but not showing the correct display quality on my screen Mac book pro i7 with Mavericks 10.9.4.
If you have both installed in folder Programs always the one you don’t want
to open will open ;-). Select Spotlight, type Freeway and choose the one
you wish t open.
Bad display performance? Placed images only or overall? I use Macbook pro
i5 with Mavericks but don’t see difference in comparison with my iMac.
2014-07-14 13:19 GMT+02:00 Kobrzinowski email@hidden:
Thanks Andries for answering.
FW 6 opens, but I have still bad display performance including opening dialogue, toolbars etc. except of the above scroll menu which is fine.
I think it has to be something with your display settings. Have tried
another screen resolution just to see if its improving?
2014-07-14 13:49 GMT+02:00 Kobrzinowski email@hidden:
