I just upgraded to version 7. Everything looks just fine but after I uploaded the main menu is not at all what I have in Freeway. It just comes out as a generic menu. I had a CSS menu that was nicely styled and spaced. I can’t figure out why in Freeway everything is normal but after uploaded the browser shows something generic. The web address is www.stseraphimcamp.com
Strange. It looks as though the Action just isn’t running for some reason. Can you send your file into support(a)softpress.com so we can take a look please? If it’s larger than 20MB then please send through http://fling.walterdavisstudio.com/ or if it’s larger than 100MB then use http://wetransfer.com
Cheers,
