Anyone know why when uploading any changes to my site, FW uploads the whole site over again? Very frustrating as I have a very media rich site that has lots of Flash video posted. I reviewed the forums and found the same issue arising in earlier versions of FW ( I also had the problem in 4.+). This seemed to go away in FWpro 5.5.1, but has returned in FWpro5.5.2. I tried to use the work around: File>Document setup>Output>resources>Common resource folder. to no avail. Help!
Tried both anyway. Still have the problem. Should I be using the common resources option in Doc Setup? Help. Very boring waiting for vids to load every time.
I set to common resources and it seems to work fine. I restarted the program, not the computer. Everything seems to be working smoothly now. Uploaded a new episode with two iPhone versions this morning without having to reload all the other content on the site. It took around 5 hours to finally get the whole site posted yesterday. The issue for me may have been due to the fact that I had just upgraded to 5.5.2 and FW might have needed all the content to be updated to match the new version? Only a guess. After two failed attempts to upload, I Disconnected the “i” versions of the videos to decrease the file size and uploaded the .flvs first, then i reconnected the m4vs and uploaded. Once I had everything posted, I was then able to do new postings without a full site upload. www.stuckinlodi.com
Hi David, I’m still not working. It’s busy loading everything yet again. Taking 2 hours each time. I’m using common resources. Have restarted the program and the Mac. I am also using 5.5.2 and converted the site from 5.5.1.
Try going to the Document Setup dialog (in the File menu) and changing the Site Folder for a new one. Also, try going clicking the Resample All button in the Edit >Resources dialog. If it still does it could you get in touch with support? They may ask for your file to help them pinpoint the problem.
On 8 Nov 2010, at 16:17, scoutdesign wrote:
Hi All,
Still having this upload problem. I am using common resources on 5.5.2. Joe or anyone out there, can you help!
