[Pro] Uploaded anomaly
At the site I’m working on located at
http://www.web.me.com/martinrice1
the border around the frame shows two small breaks on either side. In FWPro, however, I don’t see these breaks.
Any idea about what might be causing them?
Your link doesn’t work for me but I suspect that you have some table based elements in there (Not layered) that are breaking apart.
Should have green borders.
In FW’s view menu Check (tick) View>Outlines and View>HTML Layout
The first will show the colours of the bounding boxes and the second will show places where your layout is likely to break if there are non layered items in there.
I should add that table positioned items (not layered) have blue bounding boxes.
What a dummy am I. The link shouldn’t have www. Here’s the corrected link.
http://web.me.com/martinrice1
Sorry for the stupidity.
Yes - all table based, CSS button off and no layers.
Go back to Walters instructions and try again with CSS on.
You will have to redraw. Turning CSS button on won’t affect Items already drawn - but you can select Items in in the Inspector, that are not children of another Item, and tick the checkbox for Layer.
Colin
Or. maybe make the box with the border an html box rather than a graphic box.
I know that solves similar problems of color breaking up like that.
Bob
Thanks to everyone for all the help and answers. What has worked was to turn CSS on and then redraw the border. I’m sure some of the other suggestions would have worked, too.
Again, I really appreciate the help.
