I am having a horrid time trying to upload tobesite.com It looks as though it uploads but when I go to open it in any browser it displays a page that was downloaded years ago.!! I am running Mac 10.7.2 and using Freeway 5.6.1
Got an FTP app? It’s well worth having one to shunt files around when Freeway doesn’t need to be involved. If you FTP to the folder, you can check if the files on the server to see if they are the ones are the new ones or the old ones.
If the server tallies with your local files, then there may be other things at play. Your ISP may be caching files. This can be a right PITA because these caches may not clear for a few hours. However, you can generally force them to show new content by adding a ? to the end of the URL: Example Domain?
If there is a difference in the files, then check your Freeway’s FTP settings to check that it’s uploading to where you expect.
