I have started a web site in 5.5.1 but cannot seem to upload. I can access the hosting site via FETCH no problem and I have not copied and pasted the details into 5.5.1. Freeway stops responding on the ‘comparing files’ notice. No files are uploaded onto the site at the moment.
Can you check the Save FTP Log option and try uploading again with the FTP Mode set to Passive and then to Non-passive. Can you then send the FTP Log (stored in ~/Library/Logs/Freeway 5/FTP Logs) to support(at)softpress.com please?
On 22 Sep 2010, at 17:42, scoutdesign wrote:
Hi all,
550 /Testing: The system cannot find the file specified.
This is what the log says on the last line. I’ll try again with a different set up tonight and let you know how it goes. It’s looking for the right directory but can’t see it.
Have you entered Testing in the Directory filed of the upload dialog? If so you’ll need to create the folder on your FTP server before uploading or add the folder in the Site panel section of your Freeway project and move all your pages into it.
On 22 Sep 2010, at 17:54, scoutdesign wrote:
Hi Joe, how you doin’?
