When you say remove, do you mean make the site respond with nothing but an error message? Or do you mean show a friendly page like “Coming soon”?
For the former, go into your hosting provider’s cPanel or equivalent, find the site in question, and point its Apache hosting at an empty folder. You can make a new empty folder in your account area using either a SFTP application like Transmit, or your cPanel (usually). That will make the server and domain continue to work, but will “break” the site, leaving 404 errors everywhere.
For the latter, make sure that mod_rewrite is turned on in Apache (most hosts have it on by default), and add (or edit an existing) .htaccess file to contain these lines:
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} \.html$
RewriteRule ^(.*) coming_soon.html [NS,QSA,L]
First line turns on the feature, next line filters only html pages to be processed (this will allow you to have images on your Coming Soon page without having them trapped by the same trick. Final line takes every input URL that ends in .html and translates it to coming_soon.html (which needs to exist at the root of your site folder).
On Feb 12, 2017, at 5:56 AM, Roger Burton email@hidden wrote:
Hi chaps, a client has a problem (don’t they all) and wants me to remove a site for a couple of weeks, what’s the easiest way of doing this please (ie I want to be able to re upload later with as little effort as possible)
