[Pro] using JW Player or ????
I need to learn how to embed video to a website for a customer.
I have checked out JW player and want to see how to upload the videos, and put a player in place with a selection playlist beside the player.
What is the best way to do this and what is the best file type to use to have good quality, yet small file size?
I am open to some suggestions.
Rich
This might help http://www.deltadesign.co/fw_examples/jwplayer.html
Dave,
I got it to work, just can’t get it to work as an inserted item. I have to put it inside a background that expands, due to other content.
But, when I did get it working, it put the player underneath all of my other artwork at the bottom, instead of the top, whether or not I had layer button on.
Ideas?
Thanks for your help.
I appreciate it.
Rich
Markup items can be pasted inside other HTML items ie inline construction.
So this shouldn’t be an issue. Post a link to what you have already.
Dave,
There is a jw player on this page, but it is not showing up. It is in the middle of the rainbow box.
I have it inserted into the html as a layer. It will not show up. If I change it, it goes below the box.
Can’t get it to show up right. Probably something to do with the path.
Thanks for the help.
Rich
Here is the link:
http://www.cbcknox.org/churchvideospage.html
It looks like your Div - item1 - should be the JWplayer container. If that is the case then it has to have the name container.
Look in the inspector with that item selected. Title: container
Dave,
I got JW player’s pre-produced video to play.
Can’t get one of our wmv, .mov or .flv to play.
Also, cant the the box to move to the right, no matter how much margin I put on it.
Too tired…going to bed. Cats got me up at 5:30
Tomorrow is another day !!
Still can’t get things to line up right with JW player.
The inserted html item will not go flush right, no matter how much space I add to the margin on the left side.
Any ideas???
Rich
Not without seeing your page - if you want to send me a link to download your FW file - just that 1 page - I can have a look.
