After a little curiosity got the better of me, I’ve had a go at using the rem (root em) as a unit for specifying type sizes.
This page got me going:
I’ll let the page do the explaining, the more interesting part for me, was getting it to work in Freeway.
Step 1. Page menu → Html Markup… → After html:
html { font-size: 62.5%; } }Step 2. In the Freeway ‘body’ style, use the extended attributes and add the following:
Value: 16px; 1.6rem
Step 3. Size all the styles required, using the method in step 2
It seems to give consistent results across browsers, with the minor disadvantage that older versions of IE are forced to use the pixel value, and therefore the browser can’t resize the type. The big advantage, for me, is that sizing type becomes relatively easy, with none of the complications of using ems and sizes compounding.
Now, it could be that the method outlined above is frowned on — I’ve no idea — but it seems to work. An example is given in the link.
http://www.communique-test.co.uk/JEA/
