Is the Validate Form action supposed to work with Inline Form elements ?
I have a Table which has Form elements contained within it and i have tried to use the Validate Form Suite, which seems to “Attach” itself to the element ok when you set it up but then when the page is loaded and the form submitted it is apparent that No Validation is taking place.
John
actionsdev mailing list
Can you post a link to an online example as this should not be an issue.
Strictly speaking this is not an inline construction.
David,
My apologies, forgot to add the URL, here it is.
http://www.reenoserve.com/GHYC/ghycshop.html
There is one small form on the page.
Thx
John
So are you trying to combine the PHPFF action with a PayPal buy now button?
David,
Tim did some work for me on the standard PHPFF and it works fine.
John
Then if there are mods he will have to advise you about interaction with the Validate Suite.
This example http://www.deltadesign.co/fw_examples/register.html does a similar job to yours with validation.
Thx David, i had already had a brief chat with Tim before raising the issue here.
John
I want to create a blog which way i can put in it a page in which people have to write their data? i mean name------surname-----etc
waltd
(Walter Davis)
January 30, 2013, 3:20pm
10
Have you looked at Disqus? There’s an Action for it from Softpress, called Discussion IIRC.
waltd
(Walter Davis)
January 30, 2013, 3:31pm
11
Sorry, Comments: Comments - ActionsForge
