[Pro] validate.fwaction
This action fails. It doesn’t work. I use Freeway Pro 6.1.2.
Does anyone know this problem and how to handel it ?
Thanks in advance…
http://www.heilig.nl/wayfree.html
actionsdev mailing list
Thanks in advance…
I give some more information about the text in the first picture. It sais: Javascript failure. A failure was found in the Javascript of the Action “Validate”
Can anyone help me out, please ? I work with OS 10.6.8
Not sure if any of these things may apply in your case:
Do you have the action applied to anything that’s on the pasteboard rather than on the page itself? That can cause a ‘fail’.
Is the action applied to an element it’s not designed for?
Have you enabled AppleScript in Actions? FreewayPro > Preferences > General
Only other option would be to delete the action totally from your website making sure it’s not stored in the site cache and then re-applying page by page, testing as you go along.
All the best
Gordon
https://www.gordonlow.net
