[Pro] Validate
Hi,
Is anyone able to see why Validate is not working on this page?
http://www.kbstudios.co.uk/contactus.html
Simon.
The reason seems to be that I had applied the PHP Form Action to the form container rather than the page.
Your page is valid as far as I can see:
http://validator.w3.org/check?uri=http%3A%2F%2Fwww.kbstudios.co.uk%2Fcontactus.html&charset=(detect+automatically)&doctype=Inline&group=0&user-agent=W3C_Validator%2F1.3
Thanks Thomas. It could be that you were viewing the page after I’ve moved the PHP form action to the page rather than the form container, which cured the problem.
If you change the input name from ‘Name’ to ‘name’ it will help the PHPFF action do its stuff.
Read the section on Special Names at http://www.freewayactions.com/product.php?id=019 for more info.
