Hello,
Is there a way to make a vertical graphic line to “grow” (or rather go “down”) when a (variable) WebYep text box expands. I made a footer with the action: “Make the item to a page footer”.
Thanks, Lode
Not sure what the Footer reference has to do with this?
Tell us more about this ‘graphic’ that you want to expand - can we see it?
My thinking would be towards a vertically tiling bg image but that would depend on your graphic.
Hi,
I’ve been off line for a while.
Testing with some HTML “graphic elements” (grey/green), green is a layer, just to see how they react when I put some long text in the “web yep item”. What I want is that the lines grow as well.
admin
“empty”
(I don’t know where the grey “horizontal line” is coming from)
www.roselnet.com/testlines.php
(There is a double thread about this: “No subject” and “Vertical graphic line”)
Thanks, Lode
Ahh - vertical (which I always interchange).
Now basically - I’m unsure why you have a table-based construction? Is there a special reason for this?
Well basically just draw a html item on your page, chosse the middle picker of inspector, choose the margin area and set there your border.
Apply the “Wy RichText” to this item by selecting it and element, actions, wy richtext and you should be done.
