Hi all,
have followed all instructions and have tried lots of different methods of getting my video to work. but it comes up with the quick time logo and a question mark. http://www.walm.co.uk/gallery.html
it does work when you view the preview from freeway on safari.
any ideas?
Easywebanimator mailing list
Works for me.
What version of FW are you using?
The 5.5.7 update addresses some QT issues http://www.softpress.com/kb/questions/250/Freeway+5.5.7+Release+Notes
But not sure if this is relevant to your problem.
Incidentally - how large is the mov file
And I should have said that this section - EWA - is really for problems/issues with Easy Web Animator - a Flash generating companion application to FW
Hi David thanks for having a look, fortunately i have sorted the problem now so it does work, but very slowly. im using fw 5.5. i shall have a look at the update thanks. mov file is 133 mb. where should a post like this go? sorry very new to this!
thanks again will
Your movie file is a bit too large then - which is part of the problem. How did you create it and did you use Fast Web Start?
And this sort of post should go in the main FWT section http://freewaytalk.net/forum/view/5
