The Auto-Glide setting starts an automatic navigation when the page loads, but any interaction with any other navigation (tabs, buttons) stops that automatic navigation. This is by design. You can create buttons to pause and restart the auto-navigation in addition to the previous/next behavior using the Carousel Button Action, and if you create a start button, that will possibly give you what you need here.
On Mar 16, 2012, at 12:13 AM, Hoffman wrote:
is absolutely the best!!!
Thanks Walt for an amazing job.
Does anyone know if I can have the Carousel auto change but ALSO have left and right buttons to manually move?
I know you can have either but not sure if BOTH are possible.
if so does anyone have a link to example?
Thanks much,
Walt for some reason when I adjust the setting in the carousel Auto glide Interval and Effect Duration Nothing changes with the carousel right now. I do believe it did it when I first made it. I tried all sorts of numbers and it did not change.
I also have 2 carousels and changed the setting of each to be different but they still move exactly in sync. I tried diff browsers too.
I know it is something I am doing (or not doing).
Do you know why changing the #;s would have no effect?
i even just changed it from horizontal to vertical and still stays the exact same horizontal. Obviosly the settings have been disconnected in some way.
Becuase I have the transition effect only on the INDEX, when I changed the settings it did not take effect on the INDEX becuase it was broken. It did change on the other pages and that is how I knew it works.
I have to remember EACH time to change it on Master and INDEX!.
If I have 2 carousels (1 on top of each other) that are set to the same times in the settings, they move “together.”
Is there a way to have 1 button manually move both at the same time?
I put in a graphic arrow and applied the carousel button action to previous and it moved 1, then I went to it and hoped I could add the action again and was going to choose the other carousel but it did not let me put the action on twice.
Would it be possible to get 1 graphic to control 2 carousels?
