[Pro] Web site in iPad appears very small
My site functions as fully as designed on the web.
However on an iPad the site appears about 2’’ high x 3" wide. What did I miss for my site to appear properly both on computers and on iPads?
Joe Palsa
A link to your site would help us
If you are talking about joepalsa.com then your iPhone/iPad settings are
width = 960, height = 740, initial-scale = 0.50, minimum-scale = 0.25, maximum-scale = 1.60
Ie your initial scale is set to 50%
You will find the site-wide setting for this in File>Document Setup under the iPhone Tab but it can be set on a page by page basis as well. Uncheck the initial scale setting or set it to 100%.
Thanks Dave,
Sorry I didn’t include the site address. You got it right.
Thanks again,
Joe Palsa
I assume that you haven’t changed the pages yet.
I just reset it and uploaded the site.
If you have done it in File>Document Setup only then you will have to change each individual page as well. File>document Setup will only affect new pages you create not existing ones.
Do it on your Master(s) first and then check the child pages - you may have to do them too.
At the moment the pages are still the same online.
Thanks Dave,
I really appreciate your help. I just changed all the pages. What I did notice is that the iPhone menu was stubborn and kept changing the width to 980 wide when I put in 960 wide. I finally got it to stick at 960 wide.
I am still seeing your Initial Scale set at 50% - it should be 100% or unchecked.
Thanks for your patience Dave,
Done.
No probs
