[Pro] Web Yep Loop
Hey all,
I’m using WY Loop on a page with several elements inside of the loop. One of those elements I want to make Global so it shows up on another page on the site. However, I do not want the element to be global within my loop.
Is there a way?
Billy
Hi Dave
All you would need to do is create your loop as standard but use the loop start on a div Item/Action/Loopstart rather than the stand alone loop start item, then copy the same loop to another page or pages and then use checkbox next to the loop start field name (which should be called the same as the original)l, which says duplicate loop. It will then allow you to choose from the drop down the page which the original loop was on.
max
