Quick question - missing something basic - I am getting an A letter with a accent over it before my £ symbol - not in the tex edit field in Yeb Yep but appears on the web page when published. Can anyone help please.
Also, I’ve found that if it doesn’t ‘stick’, then just delete the original £ symbol in the WebYep window and just retype it and it works fine. Also, copying and pasting from another document (unless it is plaintext) can cause this problem.
for jumping in first - checked the config-file and it was UTF-8
then the other Trev jumped in so a combination of the 2 sorted it the Page Encoding set to UTF-8 seems to have fixed it.
I must admit I normally just leave it on Automatic - I have learned something today!
Many thanks Thomas and Trev for the super fast response.
I only have used basic text entry with Web Yep. Now I need to set up several offers on a page that can be edited. Obviously if I duplicate the Offer and its yeb yep content - on edit it will change all the items. My test page: http://www.professional-travel.co.uk/pt/cruiseoffers.php
Each offer is a graphic box with the elements just placed within and styling attached. Is this something to do with “Loop”
Trev, without seeing your file (and I’m no great WebYep guru either) my initial thoughts would be that each duplication of the original WebYep loop will have the same name in the WY actions palette - it will change to ‘header-1’,’ header 1a’ etc in the Freeway inspector but may remain the same in the WY palette.
Just check that for starters and see how that goes. If still no joy, then feel free to send me your FW file to look at and I’ll see if I can fumble through - remembering that I’m still on FW 5.6 at the moment.
On 12 Apr 2013, at 11:55, t50ufo wrote:
Thanks (the other Trev!)
As you use Yeb Yep - can I pick your brain?
Good stuff, pleased to hear it. I seem to be building WebYep into all of my new sites now as it’s so easy for everyone to get along with.
I’ve never managed to get the RichText editor to work yet though in any shape or form - but that’s another matter…
On 12 Apr 2013, at 12:27, t50ufo wrote:
Good man Trev!
Yes, just changing the fieldname for each element in the next offer box seems to do the trick.
