I have one of my sites that gives an error message typically on ATT network that says “cannot be viewed or accessed” The site was done in Freeway 5.5. I have sites that are in 5 that do not have this problem, in fact, I have some very complex sites that view quite easily. My client is getting upset because it has an online reservation link and he can’t access it. Is this an ATT issue or a Freeway problem?
Okay, so the page code has problems. How in the world could Freeway let that happen!
Well, the answer is simple-- Freeway let’s you (and me) paste all kinds of additional, non-Freeway generated code into our document as markup. If the code we add into the document is misspelled, malformed, or otherwise “garbaged”, then Freeway preserves it because Freeway is trusting us to NOT put garbaged code into our document.
A different source of problems for your page may be the result of the non-mobile-friendly table layouts you used to build your page. I can’t say for sure, but if I were a smartphone, I’d reject your page code too. But you might start by scrutinizing and fixing the added code markup.
Dave,
I never created a m.version of this site. I did this site 5 years ago and I did not write any code for this. I let Freeway create it. The only code inserted was for the reservation button so maybe that is the problem as far as added code markup.
CB
Thanks Dave, I have taken care of it thanks to you! You won’t believe it but it was the client who hired a 3rd party tech guy unbeknownst to me to make their site mobile friendly and gave them access to the server. Go figure. They never asked me if I could do that for them. I am now going to create a new website for them in 7.0!
Thanks for the help & have a great holiday!!
Clark
