Does the Webticker Action work with the latest version of Pro? I have installed it however the Action does nto appear in the Action list…
John
Apologise all, just sorted this issue I was looking in the wrong menu, this Action is in the item menu
John
Omar_K_N1
(Omar K N)
3
Hi,
As an echo to the above question, it seems WebTicker does not work with FRW 6.x.
Anyway, the action does not produce a script in the page, only the instance:
div id=“wtickeritem” onmouseover=“TICKER_PAUSED=true” onmouseout=“TICKER_PAUSED=false”
url: http://www.abc.se/home/m9783/ir/frw/07/
Maybe one should try the NewsCycle Action?
It worked on FRW 5.6
with best regards,
Omar K N
(Stockholm, Sweden)
Hi,
Seems to work OK for me on 6.0.7
John
ok good for you!
However as can be seen in the testpage, url: http://www.abc.se/home/m9783/ir/frw/07/
where it says: ”Select the Mail option” there should have been the Webticker.
And in the code, I can’t find a javascript!
It should be somewhere.
bw,
Omar KN
Omar_K_N1
(Omar K N)
6
Hi, John & all the rest of us:
Webticker is working now, however I have no idea what was happening,
except that I fiddled with in different ways.
At one time the same Webticker went from R → L in FFOX but L → R in Safari !
I guess these are very buggy scripts or another script interfered!
with best regards,
Omar K N
(Stockholm, Sweden)
