The Review area near the bottom is a webyep item and what I want to be able to do is, when the client enters too much text into the box, for the background graphic (it’s a sliced image) to expand downwards - instead of the text simply overlapping it. Just now it’s not an issue, but I’ve had to make the background image very long, as you’ll see, so that this doesn’t happen.
Is there anyway to make the image expand automatically?
I think that to get this you want to use inline items.
You can for example have an html item within which you paste another - with
a web yep action item in it. Independent yet following inline after that box
you can paste an image - which always moves down the page if the preceding
text box grows. (Might have to be a layered item for this - not sure)
hope this helps
regards
Brian
Fergus T said recently:
Hi there,
I’ve been having a bit of trouble with WebYep (FWP5)
