is it possible to make a horizontally webyep loop?
e.g. to position the loopelement (in my case a tabel with headline, picture and copytext)) within a container (layer) and when the width of this container is reached the loop continues in a new line?
thx in advance
The way to do this is to make sure you add just a tiny amount of padding to the container, and that the loop end sits next to your table (do not add a return) rather than under it.
i’ll get nuts. in freeway the items are shown horizontally aligned (loopstart / -element / -end) but if i open the generated php-file in dreamweaver they’re vertically …
