[Pro] Webyep horizontal menu in 6
Hi everyone,
I would like to build a horizontal menu with WebYep funcyionality in Freeway 6. Found this older tutorial by Max (http://www.freewaytalk.net/thread/view/82467) but it tells me to set the page to html3.2 output and that’s not an option in Freeway 6.
Is there another tutorial or way to create this?
regards
nobody :slight_smile: …?
Hi Thats a very old tutorial
in reality its basically the same instructions but just name the navigation myMenu in the inspector palette
and paste the styles into the css file which is created by scriptmaker and link to that css file using script linker
Here is a link to an example:
https://dl.dropbox.com/u/4274685/FileChute/webyep-horizontal-menu.zip
if you have any problems just email me directly
all the best max
Thanks max, you saved the day…again
