I am trying to create a Loop of Short Text entries, however i need each new added entry to be placed on a new line.
How is this done, i have searched for possible solutions but cannot find anything that addresses this point.
thx
John
in simple terms you want to insert a ‘loop start’ item
return
then a ‘short text’ item
return
then a ‘loop end’ item
make sure you click ‘looped item’ in the action box
have a look at the manual on page 22 for more detail
Ok, Maybe i should have been a little more specific in my description of the problem.
When i created the loop as indicated, in my example when you add a new item to the loop in puts in on the same line as the previous loop element.
What i am trying to do is force all new added items to be put on a new line.
thx
John
Ok,apologies, just re read your response.
Got it now thank You
Did not realise the significance of your word
return
in the response.
