As you can see from the test page- the Freeway html-drawn menu items display correctly (letters/accents).
However the text pasted into the WebYep long text entry does not display its letters/accent marks correctly (even though they appear correct when pasted in the box)
Can anyone tell me how to fix this? I need to display Portuguese correctly— otherwise WebYep isn’t going to work for this site.
Hi
could you open up the config-inc.php with a text editor within the webyep system and change two setting
they on line 41
change this from:
$webyep_sCharset = “”;
to this
$webyep_sCharset = “utf-8”;
then on line 55 change the
$webyep_sHTMLStandard = “auto”;
to this
$webyep_sHTMLStandard = “XHTML”;
and then finally on line 121
$webyep_sLang = “auto”;
to this
$webyep_sLang = “portuguese”;
that should do it
what I have done is change the webyep interface to Portuguese
then correctly set the character encoding to match your out put and finally changed the document type to match freeways doc type
