Is the WebYep Action still useful with Freeway Pro 7. I have WebYep 1.4.5. Should I update ?
Hi Peka I am assuming you are referring to the webyep system 1.4.5. as I never release a 1.4.5 action
The webyep system is at present on version 1.8 but version 2 isn’t far off
As for its usefulness it all depends if you need a content management system? if you could describe what you are trying to do then i could give you some advise on weather its appropriate for what you want to do
speak soon max
Hi Max,
yes you are right, the web yep system is version 1.4.5 and my web yep action is from year 2008. I don’t know the version number.
I need some kind of system where my client can update by him self only one page. This page he will tell about the offer of his company. I’ll think there could be several elements of different offers. One offer have the title, a little bit text and a photo with price.
The site I have made with Freeway Pro 7.
hi Peka
could you send me your email address and i will send you the update. WebYep is quite capable of doing what you want it to do.
Max
hi Max,
here is my email address: email@hidden
Thanks in advance.
PeKa
The FWT web site has a feature that obfuscates email addresses so unless you use the format myname(at)mysite.com they will be turned into email@hidden.
Not sure if Max interacts via the web or email so he may or may not have your email address.
hi Peka
could you just email me your address its easier that way…
my address is readily available from my site
cheers max
Hi Max,
sorry Max, but I don’t know what is address to your site!
my address is max-izzat.co.uk
email address is max.izzat(at)virgin.net
all the best max
